TwinTurbo.NET: Nissan 300ZX forum - Det Sensor wiring breakage is a pretty common issue
Subject Det Sensor wiring breakage is a pretty common issue
Posted by jzack on April 17, 2008 at 10:22 PM
  This message has been viewed 150 times.
In Reply To engine problem posted by Jaskozx on April 17, 2008 at 08:46 PM
Message too (due to age and heat). Wiring breaks up on the top of the plenum where the wiring comes up from below and plugs into the main harness connector (behind balance tube, mid section). Pretty easy to visually check and see if that's happened - fairly easy to repair too.
